aroldan's avatar
aroldan
Initiate
Jun 13, 2018
Netgear Nighthawk X6 R8000
Netgear Nighthawk X6 R8000 Firmware Version: V1.0.4.18_10.1.49 (latest as-of 6/13/2018) Having an issue with the Wireless Signal Schedule in: Advanced tab --> Advanced Setup --> Wireless Settings....
  • aroldan's avatar
    Jun 18, 2018
    Ok Netgear, now it's up to you to fix the problem. I ended up having to revert back to the previous firmware version to be able to check-mark the Turn off wireless signal by schedule. I dare anyone using the schedule to go ahead and remove that check-mark; you'll be locked-out of being able to re check-mark it, making the schedule useless.
    I now realize Netgear continues to have issues with their firmware that they don't care to address in their own forums.
