hom's avatar
hom
Netgear Nighthawk X6 (R8000)
Currently I have a Netgear R7500 router located in my bed room (wired with Ethernet). When there’re 3 iPhones, 3 iPads and a laptop in the living room connected wireless with the router at the same t...
  • mondenath's avatar
    Oct 17, 2015
    See repeater nor extender may improve but only to certain extend.
    The possible solution i believe is that get a nano if not Gigabyte powerline adaptors in the room when signals are week. Use the existing repeater to extend the signal through powerline .
    This way you will get best signal and also close to 100Mb/s speed or atleast 50Mb/s which is decent enough unless your ISP speed is not more than 200 Mb/s
