keviehinds
Dec 15, 2021Aspirant
Netgear Nighthawk X65
My Netgear router has started beeping, about every 15 minutes. I have unplugged but still happens. An ideas what this may mean? Thanks!
Dec 17, 2021Guru - Experienced User
Interesting, have never heard a NG router beep before. Routers usually don't have peizo speaker installed.
You sure it's coming from the router?
What happens if you disconnect it from the ISP modem and disconnect all wired devices from the router and turn OFF the wifi radios?
Has a factory reset and setup from scratch been performed yet?
Thanks!
