Razerhd
Aug 31, 2022Aspirant
NETGEAR Nighthawk X6S (R8000p) AC4000 having issues getting full gigabite download speed.
So I recently upgraded to Spectrum's 1 gig along with their Sercomm ES2251 from their 400mb package & for some reason when I do a speed test it will cap out to 947mbs at it's highest. I say at it's h...
- Aug 31, 2022
Maybe a choice however the router IS only designed up to a certain point and capabilities of the router at the time and what the internal components were designed for. Also there Is bandwidth overhead as well that is at play too. All this is nature of the beast and would be the limiting capabilities of ANY Router of the age and support. Been like this for a while now. 800-900Mbps is nothing to shake a stick at as the router is working at it's max capabilities. If you want to see speeds on the WAN to LAN side over 1000Mbps, you'll need a router that supports 2.5Gb connection rated ports on the WAN and LAN side.
Razerhd
I've powered it off many times for 1 minute. Had to when to connecting to modem from pc due the network not recognizing it.
CPU is pretty up to snuff. Ryzen 3800x with an Asus ROG x570 Crosshair VIII Formula capable of 5 Gbps LAN.
As for the range with the router, well, was hoping it would at least cap out at 1000 mbps but I can see if that 800-900 is it's range then well I made a poor product choice.
Aug 31, 2022Guru - Experienced User
