gjfconsult
Oct 29, 2021Aspirant
Netgear Nighthawk XC 8000 Schedule
I have been running the block schedule for some time and it works nicely. I've allocated ip addresses and block them at a point when the kids should go to bed with the schedule. It stopped working re...
Oct 29, 2021Guru - Experienced User
Can you confirm this? "XC 8000" XC isnt' a valid model#. R8000 maybe?
Has a factory reset and setup from scratch been performed since last?
gjfconsult
Yes. You are correct x6 r8000 is the model.
No, I've not done a factory reset. It seems rather xtreme.
- FURRYe38Oct 29, 2021Guru - Experienced User
Something to try.
If this just started after a FW update, you may need to revert back to what had worked.
