pszabo's avatar
pszabo
NETGEAR Nighthawk(R) X4S R7800 - Can not properly reconnect to ISP's cable-modem
Hi All!
I've problem with my NETGEAR Nighthawk(R) X4S R7800 router.
My router can not reconnect properly to the internet after my ISP's Cable Modem is restartting.
Every time after modem restarts I can see a red Disconnected label under Basic / Home / Internet tab, and of course no internet access for my gadgets at home.
To get it work I have to go to the Advanced / Administration / Router Status page, there at Internet Port block I have to choose Connection Status, and within that popup I must click on Release than a bit later onto Renew.
Afterwards the net will start working fine.
Why my R7800 is not capable to reconnect automaticaly properly?
I have a older WNDR3400 router also - with DDWrt Firmware - and it's handling fine the cable modem restarts, but the R7800 is not.
WF version on the R7800 is the latest 1.0.2.92.
By the way when modem is restarted I can see the R7800's log as it first receives a class C IP first (192.168.100.x) than couple seconds later it receives the proper A class address from my ISP (89.133.x.x)
My modem is set to work in bridge mode and IPV4, and as I know it boots into normal mode first, than it switch to bridge. It's provided by my ISP (Vodafone Hungary), it's labeled as "Vodafone TG3442DE" but as I know inside it's an Arris modem. (Firmware version AR01.02.068.11_092320_711.SIP.10 , Hardware Type & Version 11 )
I appreciate any advice, idea about this issue!
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
    • pszabo's avatar
      pszabo
      Hi FURRYe38,
      Thanx for your reply. Here I'm answering for your questions inline.
      "What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?"
      There is no any other label on the outside just as I wrote previously:  "vodafone   TG3442DE"
      As I know it's a  "Arris Touchstone TG3442DE"  modem
      "Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. "
      I'm using Cat5e cables since years without problem.
      "Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?"
      Yes, no help.
      "Be sure to restart your network in this sequence:
      Turn on computers and rest of network."
      I did it several times.
      "Has a factory reset and setup from scratch been performed since last FW update? "
      Yes
      "A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch."
      I've done it already, no help.
      You've to know, I'm an IT engineer (SW developer) and I'm over of all the basic things. I've used the R7800 via my ISP's older modem (a Compal modem for 500mbits), and I did not experience any issue. If the modem has been restarted sometime, I do not even realize it.
      But now, with this vodafone / Arris modem which I got for the 1000mbits subscription I've got this issue.
      Due to some ISP side problem the modem restarted itself very often (1-2-3 times / day) and every time I had to use the Release than Renew feature to get proper internet connection. Of course if I reboot the R7800 that also solved the problem.
      Even after couple hours later the router does not properly reconnect -by itself-.  (only manual relese/renew or reboot helps)
      The strange thing is that my old WNDR 3400 (with dd-wrt) does not produce such problem, that is simply reconnecting after the modem restarts. (no need to release/renew or reboot)
