WendyWong
Aug 22, 2022Follower
Netgear Nighthhawk AC1900 Smart Router
Had no wifi connection. Verizon fios connection is fine. So I unplugged netgear router, also 'reset' router. Netgear router is an available wifi network to connect now but problem is router won't take...
Aug 22, 2022Guru - Experienced User
You may need to factory reset the the router as setup from scratch.
