eveluwenkamp
Mar 16, 2019Aspirant
Netgear Portforwarding Problem after using the IOS app
After login via the IOS app into the router and set some settings the app, the port forwarding list is empty (this is reproduce each time). Also when the missing forwards port are added after this in...
- Mar 20, 2019
The discussion can be closed, I have replace the router by another brand, this router is stable.
DarrenM
Mar 20, 2019Sr. NETGEAR Moderator
Are you using the nighthawk app or the genie app?
DarrenM
- eveluwenkampMar 20, 2019Aspirant
