RASSER2's avatar
RASSER2
Follower
Aug 15, 2019
NETGEAR ProSupport for Home - Extended Warranty
I have a Nighthawk AC1750 Smart WiFi Router, and fascilating on the purchase (or not) of the extended warranty.   Before I purchase an extended warranty, I would like to get its description. And, d...
  • michaelkenward's avatar
    Aug 16, 2019
    First, AC1750 is not a reliable guide to model number. Many devices come with an AC tag. It is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    RASSER2 wrote:
    Does anyone have any issues with the warranties, or not having their warranty?
    What do you want a warranty for? Support to fix things or in case the device breaks?
    The hardware warranty is for at least a year. Longer in some countries.
    The 90-day "free support" is basically there for getting the thing up and running.
    After that, Netgear does not sell support. It farms that out to GearHead Technical Support.
    GearHead Support
    Netgear's own support is limited to 90 days. You get that by registering your device and starting the process on the MyNetgear site.
    Many people happily use the free support that comes from fellow users who hang out here.
