skynet2001
Nov 12, 2021Aspirant
Netgear R 7000 Lan Ports not working
Hello who can help My R7000 does not use lan ports 1 and 3, ports 2 and 4 are working fine. How can i resolve this Thanks in advance
Nov 12, 2021Guru - Experienced User
1. what firmware is on the router?
2. how long have they been not working?
3. if you swap a device onto one of those ports, will it work?
4. what caused it to stop working? (storm, dropped, firmware update, etc)
5. have you tried a simple factory reset and reinstall?
skynet2001
Hello ,thanks for the reply:
1. what firmware is on the router? V1.0.11.106_10.2.100
2. how long have they been not working? From day 1
3. if you swap a device onto one of those ports, will it work? Changing has te same effect ,port 1 and 3 don t work, 2 and 4 do
4. what caused it to stop working? (storm, dropped, firmware update, etc) No idea
5. have you tried a simple factory reset and reinstall? Yes no effect
Thanks for your help in advance
