skynet2001
Nov 12, 2021Aspirant
Netgear R 7000 Lan Ports not working
Hello who can help My R7000 does not use lan ports 1 and 3, ports 2 and 4 are working fine. How can i resolve this Thanks in advance
skynet2001
Hello ,thanks for the reply:
1. what firmware is on the router? V1.0.11.106_10.2.100
2. how long have they been not working? From day 1
3. if you swap a device onto one of those ports, will it work? Changing has te same effect ,port 1 and 3 don t work, 2 and 4 do
4. what caused it to stop working? (storm, dropped, firmware update, etc) No idea
5. have you tried a simple factory reset and reinstall? Yes no effect
Thanks for your help in advance
Nov 12, 2021Guru - Experienced User
have you tried installing the latest 1.0.11.128 firmware for that router?
https://www.netgear.com/support/product/r7000.aspx
- skynet2001Nov 12, 2021Aspirant
Installed firmware 1.0.11.128(rebooted) , still ports 1 and 3 not active
Lan cable active on port 2 switched to 1 and 3 without succes
Please advice
Is attached setting ok
- plemansNov 12, 2021Guru - Experienced User
If this has been going on from day 1, I'd open a support case with netgear.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.- wcalifasNov 12, 2021Prodigy
sounds like those 2 ports are dead for some reason. You can't really do much to fix them if the ports are technically dead.
- skynet2001Nov 13, 2021AspirantHow can i check by software if Ports are defect
