johnmcyahoo
May 31, 2021Follower
NetGear R6020 is a scam router
The R6020 AC750 wireless router promises 750Mbps speeds and can only deliver a maximum of 100Mbps due to it's cheaped out ethernet ports which are limited to 100Mbps FE (a technology that was blister...
Jun 01, 2021Guru - Experienced User
So you're upset because you didn't check the port speeds prior to buying the router?
Its a base model router. it isn't going to have added features.
Jun 02, 2021Guru - Experienced User
I'd agree that gigabit should be the baseline. But sadly it isn't.
All the major manufacturers have at least 1 device thats still 100mbps port speed. And they tend to have the 1000/1200mbps wireless ratings that are aggregate. Its a industry wide issue.
here's a few and this was just with a quick search
tp-link:
https://www.tp-link.com/us/home-networking/wifi-router/archer-c50/v5/
https://www.tp-link.com/us/home-networking/wifi-router/archer-c20/v1/
Linksys:
D-Link:
https://us.dlink.com/en/products/dir-822-d-link-wifi-router-ac1200-dual-band
so as much as I think it'd be a great idea to be the new baseline, there is still a need for 10/100mbps devices and so that niche will be filled by device makers.
I'm glad you can return it to buy a new devices but make sure you're looking at the actual specs. I'd even encourage you to read a few reviews on places like smallnetbuilder for actual tested performance on them. Its a much better idea than trusting the boxes.
Good luck.
