bashdra
Nov 16, 2020Aspirant
Netgear R6260 Static Internal Route
Hey all, I am having a bit of an issue with my home/office network. I work from home and recently setup a segrated home office. My 'net facing router is a R6260. Works well and haven't had any co...
antinode
Nov 16, 2020Guru
> Model: R6260|AC1600 Smart WiFi Router Dual Band Gigabit
Firmware version? Connected to what?
> [...] added a static route to the R6260 [...]
That's nice, but, with my weak psychic powers, I can't see any of
your IP addresses or routes.
> I have tried all the rip settings on the R6260 [...]
If you're using static routes, then I'd avoid adding RIP to the
picture.
> Is there a bug in the Nat table which bypasses the static route
> configuration? [...]
Sounds unlikely, but almost any bug in Netgear router firmware would
not amaze me.
