javidr
Aug 10, 2021Aspirant
Netgear R6400 - Fibre ready?
Hi
I will have my g.fast fibre installed tomorrow and i would like to know if i could use my Netgear R6400 with that technology. Do you know if it is fibre ready? Has anybody done this before?
Thanks
The R6400 doesn't havea fibre terminal but most fibre installations have their own ONT connection or something to connect a router to.
Depending on the speeds you pay for, the r6400 might not perform the greatest. It was a base model gigabit AC router.
