SkyClipper
Aug 27, 2021Follower
Netgear R6400 AC1750 connects poorly to Apple devices
Hello, I have a Netgear R6400 AC1750 with f/w V1.0.1.62_1.0.41. I've installed Speed Test on all devices and find that Windows and Androind devices show download speeds of approx 30 Mbps while the A...
michaelkenward
Aug 28, 2021Guru - Experienced User
It helps to think of things the right way round.
Your R6400 does not connect poorly to Apple devices. The Apple devices are supposed to connect to your R6400.
SkyClipper wrote:
...Windows and Androind devices show download speeds of approx 30 Mbps while the Apple iOS devices (iPhones and Macbooks and iPads) show download speeds of only approx 2 - 3 Mbps.
That other devices connect as expected is another clue. The router is not picking on your Apple stuff. It doesn't know what is trying to connect to the wifi.
Have you been through the usual "forget and rejoin" move. Tell you slow devices to forget that they ever encountered your router's wifi and then rejoin the network.
SkyClipper wrote:
I have not been able to find a fix in the Community forums.
Did you find any similar reports on slow Apples? You won't find fixes to problems that have not been reported.
