LESLIE12
Feb 19, 2021Follower
NETGEAR R6400 AC1750 dropping internet connection to laptop
Hello Tech World, Since Jan. Internet keeps dropping 5g connection ( or timing out) to my DELL INSPIRON 3558 laptop, shows connected but-not, (have to constantly re-boot) , Prorerties window showing NETGEAR dual band wireless AC3160, Is this normal? my desk top DELL XPS 8500 seems fine. Re-booted CM-1000 reset R6400 w/no luck. Firmware V1.0.1.62 tried to update to V1.0.1.68 but having problems, any suggestions? Thanks You, from Teck grade -K
1 Reply
What problems are you having with the firmware update?
Did you try updating the intel driver directly from intel?
https://downloadcenter.intel.com/product/75442/Intel-Dual-Band-Wireless-AC-3160
