Krycha00
Oct 02, 2021Aspirant
Netgear r6400v2 problem
Hi, i think i have a problem with my router. I have version V2 (r6400v2) , but on GUI everywhere i see r6400. Is it normal?
Oct 02, 2021Guru - Experienced User
According to your firmware, you have a V2
- Krycha00Oct 03, 2021AspirantBeside firmware question - i have terrible signal on 5ghz wifi from this router. I'm standing 3m from router and signal strenght You can see on attached screen. Mobile devices are switching wifi internet to mobile data because of week signal. I bought this router to use mostly 5ghz wifi but its impossible. Changing FW didnt change antything, also parameters, channels etc. Changing antennas positions didnt change signal also. There are no other 5ghz wifi in my home.
- FURRYe38Oct 03, 2021Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalGood Luck.
Krycha00 wrote:
Beside firmware question - i have terrible signal on 5ghz wifi from this router. I'm standing 3m from router and signal strenght You can see on attached screen. Mobile devices are switching wifi internet to mobile data because of week signal. I bought this router to use mostly 5ghz wifi but its impossible. Changing FW didnt change antything, also parameters, channels etc. Changing antennas positions didnt change signal also. There are no other 5ghz wifi in my home. - plemansOct 03, 2021Guru - Experienced User
how old is it?
That device should have a pretty decent 5gh?
- Krycha00Oct 04, 2021AspirantI bought this router in January, this year, so it Has about 8months.
