Retired_Member's avatar
Retired_Member
Feb 16, 2022
NETGEAR R6400v2 Router Firmware 1.0.4.126 update
Does this update enable WPA3 security on the R6400v2?
The info just says 'security updates' w.o. giving any specifics.
  • For WPA3 you need new hardware. The R6400v2 does not support that, it's not just a matter of firmware
    • Retired_Member's avatar
      Retired_Member
      Thanks. Thought that was probably the case.
