h00jraq
Jan 21, 2021Aspirant
NetGear R6400v2 slow LAN speeds
Hi, I'm using this router for few months now and what I can see is that with few devices connected to it, Internet speed is quite low compared to max speed. My Connection is 1 Gbit and I can get alm...
Jan 21, 2021Guru - Experienced User
What modem/gateway is it connected to?
Did you try factory resetting and doing a clean install? Try that and during the install make sure to leave access control, parental controls, qos, and traffic monitoring all disabled.
- h00jraqJan 21, 2021Aspirant
I've did tried factory reset. Everything is turned off and the problem is that it looks by default that hardware offloading is disabled by default and as I know for most devices, max speed seems to be lower than 300Mbits on 1Gbit ports.
- plemansJan 21, 2021Guru - Experienced User
Try installing version 1.0.3.66 of the firmware to that router. The newer versions got netgear armor and the R6400 was borderline on having enough power to run armor. As evidenced by V2 getting armor and V1 not.
when you downgrade, make sure to do it over a hardwired connection, factory reset afterwards, and then do a clean install (not from backup)
