BethT
May 23, 2024Follower
Netgear R6700AX can't connect new router to LG tv to get internet connection
After hours getting new router to access internet, now I can't connect to the internet on LG webOS tv. TV software up to date. I am entering the correct password for new wireless network but get an ...
May 23, 2024Guru - Experienced User
What security mode do you have set on the R series router? WPA, WPA 2? Mixed.
Temporarily disable wifi security mode on the router just to see if the TV can connect to it at all. Re-enable WPA2 and AES after checking this.
Try changing channels, try 1, 6 or 11 on 2.4Ghz and try 40 or 149 on 5Ghz.
Try with Smart Connect enabled and disabled.
