BethT
May 23, 2024Follower
Netgear R6700AX can't connect new router to LG tv to get internet connection
After hours getting new router to access internet, now I can't connect to the internet on LG webOS tv. TV software up to date. I am entering the correct password for new wireless network but get an ...
michaelkenward
May 23, 2024Guru - Experienced User
Your subject says "R6700AX can't connect new router to LG tv to get internet connection".
Start thinking of it as the other way round. LG TV can't connect to R6700AX. (Is that the new router?)
Is this a wifi connection?
Most TVs have their own set up routine. You need to run the TV through that. Are you doing this?
What happens and where does it go wrong?
