OneSpellWizard
Aug 20, 2021Aspirant
NETGEAR R6700v3 hardwire connection slows down with CAT6 compared to CAT5e
As the title says, I have a strange situation with my download speed. I'm paying for 1gbps (gigabit) from Wave. For each speed I list here, I have tested it at least 2 times each on fast.com, speedte...
OneSpellWizard
Thanks for the reply! Sorry if it wasnt clear, I swapped the CAT6 cable (which already was able to get gigabit speeds if desktop plugged directly to the modem) for a CAT5e cable between desktop and router. The modem to router CAT5e cable was unchanged.
Aug 20, 2021Guru - Experienced User
Try factory resetting the r6700. after the reset, during the install process,make sure to leave qos, access control, parental controls, and traffic monitoring all disabled
- OneSpellWizardAug 21, 2021Aspirant
I did the factory reset and getting the same issue as before. Even with a CAT 5e cable, it's still ~200mbps slower (~500-600 mbps) than a direct connect of the Desktop to the Modem (~800mbps)
- plemansAug 21, 2021Guru - Experienced User
How are you testing the speed?
Each time I test I do
- 2 tests on fast.com
- 4 tests on speedtest.net
- 2 on Whitesky Communications LLC
- 2 on Ziply fiber or another server
- 2 on Google Search's speed test
