OneSpellWizard
Aug 20, 2021Aspirant
NETGEAR R6700v3 hardwire connection slows down with CAT6 compared to CAT5e
As the title says, I have a strange situation with my download speed. I'm paying for 1gbps (gigabit) from Wave. For each speed I list here, I have tested it at least 2 times each on fast.com, speedte...
OneSpellWizard
Aug 21, 2021Aspirant
I did the factory reset and getting the same issue as before. Even with a CAT 5e cable, it's still ~200mbps slower (~500-600 mbps) than a direct connect of the Desktop to the Modem (~800mbps)
Aug 21, 2021Guru - Experienced User
How are you testing the speed?
- OneSpellWizardAug 21, 2021Aspirant
Each time I test I do
- 2 tests on fast.com
- 4 tests on speedtest.net
- 2 on Whitesky Communications LLC
- 2 on Ziply fiber or another server
- 2 on Google Search's speed test
- plemansAug 22, 2021Guru - Experienced User
Have you tried downgrading the firmware a version or 2
