DRESTL's avatar
DRESTL
Netgear R6700v3 Router troubleshooting
My router seems to reset each 48 hours.  I have troubleshooted my modem, with no issues there.      Each 48 hours I have to reset (power toggle) the router.  You could set your watch to the times t...
  • DRESTL's avatar
    DRESTL
    May 02, 2020
    A quick update. so far so good. If the 48-hour repeating of the disconnection has been disrupted or eliminated by the router reset, I do not know at this point.
    A quick question though, would you suggest that I disable auto updates a firmware on the router? In the Netgear community I've seen several reports of issues with new firmware upgrades.
    As always, I appreciate your help. I'm going to keep this thread going until some time passes and I'm assured that the problem is solved.
    Dan
