DRESTL
Apr 28, 2020Aspirant
Netgear R6700v3 Router troubleshooting
My router seems to reset each 48 hours. I have troubleshooted my modem, with no issues there. Each 48 hours I have to reset (power toggle) the router. You could set your watch to the times t...
- May 02, 2020
A quick update. so far so good. If the 48-hour repeating of the disconnection has been disrupted or eliminated by the router reset, I do not know at this point.
A quick question though, would you suggest that I disable auto updates a firmware on the router? In the Netgear community I've seen several reports of issues with new firmware upgrades.
As always, I appreciate your help. I'm going to keep this thread going until some time passes and I'm assured that the problem is solved.
Dan
DRESTL
I am simply power recycling, not doing a factory reset.
My ISP is Spectrum internet
FW is V1.0.4.84_10.0.58 and I have not tried an earlier version of the firmware.
I'm making changes to the settings one at a time, and today I turned off the automatic updates, in case they were causing the issue.
Apr 28, 2020Guru - Experienced User
DRESTL wrote:I am simply power recycling, not doing a factory reset.-----trying a reset isn't a bad start.
My ISP is Spectrum internet------wth what modem?
FW is V1.0.4.84_10.0.58 and I have not tried an earlier version of the firmware.------a downgrade is sometimes worth trying after you've tried the factory reset.
- DRESTLApr 29, 2020Aspirant
Unfortunately my Modem doesnt show a manufacturer... The Model Number apparently is E31U2V1.
i'm trying to accomplish this in stages, so I can keep track of single changes, rather than guess at which multiple stage worked or did not.
I really appreciate your help.
Dan
- plemansApr 29, 2020Guru - Experienced User
So start with the factory reset. If that doesn't help.
Then try installing firmware version 1.0.3.66, factory reset again, and manually install. (not from backup)
- michaelkenwardApr 29, 2020Guru - Experienced User
Does it have a row of LAN ports somewhere? Does it do wifi?
- DRESTLApr 29, 2020AspirantIt does have two ethernet ports in the back, I have no idea if it does Wi-Fi or not.
