alchle
Feb 02, 2022Star
NetGear R6700v3 Slow speed
I've seen this issue in other posts and web, but with no resolution. Scenario: I have R6700v3 router with firmware V1.0.4.122_10.0.95. I pay for 750mbps and only get 250mbps download max with this ...
- Nov 13, 2022
Seems like the new Firmware Version 1.0.4.128 is holding up so far with me getting 475mbps on a 500mbps plan for wired..
DexterJB
Feb 07, 2022NETGEAR Moderator
Hi alchle, if you are still experiencing the issue, we recommend contacting the support team for further troubleshooting. You can start on the link below.
https://www.netgear.com/home/contact-us/default.aspx
Dexter
NETGEAR Team
dpmoore
Feb 10, 2022Star
I have the same issue and I am using a an Xfinity CM1000V2 modem. Paying for 1200Mb and wasting my $$ because of this router. I tried submitting a support ticket, but says I am past the 1yr mark.
- alchleFeb 10, 2022StarI have not found a solution yet either. Only think that helps is that I downgraded firmware to V1.0.2.66_10.0.48 and it now gets to around 550mbps (out of 750 mbps) still not what it should be. I have another router (ASUS) I think I will switch to, but I’ll miss the USB 3.0 flash drive shared across the network. The R6700 does get full bandwidth if used as an access point. But you don’t want that directly off your modem, it would become an extension of your ISP’s network and thus open to everyone. If you can put another device between the two and get it inside your own LAN then it would work great as a wifi access point. But as a stand-alone devise… NetGear has some work to do.
