alchle
Feb 02, 2022Star
NetGear R6700v3 Slow speed
I've seen this issue in other posts and web, but with no resolution. Scenario: I have R6700v3 router with firmware V1.0.4.122_10.0.95. I pay for 750mbps and only get 250mbps download max with this ...
- Nov 13, 2022
Seems like the new Firmware Version 1.0.4.128 is holding up so far with me getting 475mbps on a 500mbps plan for wired..
DexterJB
Feb 07, 2022NETGEAR Moderator
Hi alchle, if you are still experiencing the issue, we recommend contacting the support team for further troubleshooting. You can start on the link below.
https://www.netgear.com/home/contact-us/default.aspx
Dexter
NETGEAR Team
alchle
Feb 12, 2022Star
DexterJB. I tried contacting support as one of my first steps, however, technical support ended for me around 9 months ago. Hardware warranty is still good until end of this month, but it is not a HW issue. If you would be so kind and take this case to higher levels that would be outstanding! It seems to be a common problem with other users and not just an isolated issue. Probably a much larger issue too except only prevalent with those that have fast internet and cat5e/cat6 wired connections. It won’t be noticeable with wifi. Thank you. -alchle
