alchle
Feb 02, 2022Star
NetGear R6700v3 Slow speed
I've seen this issue in other posts and web, but with no resolution. Scenario: I have R6700v3 router with firmware V1.0.4.122_10.0.95. I pay for 750mbps and only get 250mbps download max with this ...
- Nov 13, 2022
Seems like the new Firmware Version 1.0.4.128 is holding up so far with me getting 475mbps on a 500mbps plan for wired..
wombatwarrior
Mar 08, 2022Aspirant
I'm having the same issue. I tried factory reset and I will get 700 Mbps on ethernet however the moment I set up the router, it resorts back to less than 200 Mbps. I tried rolling back the firmware but same issue. I believe once the router updated to the new firmware, something happened to the hard coding. I've been a big supporter of Netgear my entire life but this recent issue is frustrating. I will have to try another router brand.
- mattfinley12Mar 23, 2022Aspirant
Same problem as everyone else.. when they upgrade the firmware to V1.0.4.122_10.0.95 it dropped my speed from 480 down to now 135 or so and 5G now doesn't work.. ridiculous. The old 1.0.366_10.0.50 version gave me the best speeds and no 5G problems, but now I can't roll it back and get it to work.
I am going to try a few downgrades to see if it will fix it and if not, in the trash it goes and I will switch to another brand.
