alchle
Feb 02, 2022Star
NetGear R6700v3 Slow speed
I've seen this issue in other posts and web, but with no resolution. Scenario: I have R6700v3 router with firmware V1.0.4.122_10.0.95. I pay for 750mbps and only get 250mbps download max with this ...
- Nov 13, 2022
Seems like the new Firmware Version 1.0.4.128 is holding up so far with me getting 475mbps on a 500mbps plan for wired..
mattfinley12
Nov 13, 2022Aspirant
- WhatarusshNov 24, 2022GuideI have the latest firmware V10.4.128_10.0.104 with all the suggested setting but still speeds never above 250. This sucks!!
- KitsapNov 25, 2022Master
Whatarussh wrote:
I have the latest firmware V10.4.128_10.0.104 with all the suggested setting but still speeds never above 250. This sucks!!Recommend you start a brand new thread and in the very first post answer the basic setup questions for your specific setup. This will make it easier for people to help you with your specific issue.
What is the brand name and model number of the modem/ONT that is connected in front of your R6700v3? Have you connected directly to the modem/ONT and tested the throughput capacity?
How are you connected to your R6700v3, wired or via Wi-Fi? If Wi-Fi, what frequency band?
How are you testing throughput capacity? With a web browser connected to a web site or a stand alone application like Ookla?
What device are you using to test the throughput capacity? Windows computer, Mac computer?
- michaelkenwardNov 26, 2022Guru - Experienced User
Whatarussh wrote:
I have the latest firmware V10.4.128_10.0.104 with all the suggested setting but still speeds never above 250. This sucks!!If that is wifi speed, congratulations. It is faster than many systems can deliver. Sadly, Netgear cannot change the laws of physics.
- WhatarusshNov 26, 2022Guide
No it is NOT over Wifi it is a wired connection. my speeds wired direct out of the modem are around 450 mbs. So it appears that Netgear cannot change the laws of physics but they can change a lot of their customers 6700v3 routers into speed throttled hunks of junk! I suppose the next step is to do a factory reset and start clean. Netgear firmware updates wreck the router performance and the burden of repair falls upon the customer. Is there a law of physics that applies to crappy software releases and poor customer service Mr Guru?
