alchle
Feb 02, 2022Star
NetGear R6700v3 Slow speed
I've seen this issue in other posts and web, but with no resolution. Scenario: I have R6700v3 router with firmware V1.0.4.122_10.0.95. I pay for 750mbps and only get 250mbps download max with this ...
- Nov 13, 2022
Seems like the new Firmware Version 1.0.4.128 is holding up so far with me getting 475mbps on a 500mbps plan for wired..
Whatarussh
Nov 24, 2022Guide
I have the latest firmware V10.4.128_10.0.104 with all the suggested setting but still speeds never above 250. This sucks!!
Kitsap
Nov 25, 2022Master
Recommend you start a brand new thread and in the very first post answer the basic setup questions for your specific setup. This will make it easier for people to help you with your specific issue.
What is the brand name and model number of the modem/ONT that is connected in front of your R6700v3? Have you connected directly to the modem/ONT and tested the throughput capacity?
How are you connected to your R6700v3, wired or via Wi-Fi? If Wi-Fi, what frequency band?
How are you testing throughput capacity? With a web browser connected to a web site or a stand alone application like Ookla?
What device are you using to test the throughput capacity? Windows computer, Mac computer?
