alchle
Feb 02, 2022Star
NetGear R6700v3 Slow speed
I've seen this issue in other posts and web, but with no resolution. Scenario: I have R6700v3 router with firmware V1.0.4.122_10.0.95. I pay for 750mbps and only get 250mbps download max with this ...
- Nov 13, 2022
Seems like the new Firmware Version 1.0.4.128 is holding up so far with me getting 475mbps on a 500mbps plan for wired..
michaelkenward
Nov 26, 2022Guru - Experienced User
Whatarussh wrote:
I have the latest firmware V10.4.128_10.0.104 with all the suggested setting but still speeds never above 250. This sucks!!
If that is wifi speed, congratulations. It is faster than many systems can deliver. Sadly, Netgear cannot change the laws of physics.
Whatarussh
Nov 26, 2022Guide
No it is NOT over Wifi it is a wired connection. my speeds wired direct out of the modem are around 450 mbs. So it appears that Netgear cannot change the laws of physics but they can change a lot of their customers 6700v3 routers into speed throttled hunks of junk! I suppose the next step is to do a factory reset and start clean. Netgear firmware updates wreck the router performance and the burden of repair falls upon the customer. Is there a law of physics that applies to crappy software releases and poor customer service Mr Guru?
