alchle
Feb 02, 2022Star
NetGear R6700v3 Slow speed
I've seen this issue in other posts and web, but with no resolution. Scenario: I have R6700v3 router with firmware V1.0.4.122_10.0.95. I pay for 750mbps and only get 250mbps download max with this ...
- Nov 13, 2022
Seems like the new Firmware Version 1.0.4.128 is holding up so far with me getting 475mbps on a 500mbps plan for wired..
JSebek
Dec 12, 2022Aspirant
I've already done a lot of tests with every firmware I can find and disabling armor in settings. I have a Bachelors Degree in computer science and understand packets, network topology, network layers, what firmware does, etc etc. I'm not some misinformed average user or young person making things up or randomly guessing.
Furry, I appreciate you referencing that post in regards to the beta firmware. I did read it over but also read that the guy couldn't share the firmware due to NDA. I also see another gentleman post right after it that he tried the newest one and it still throttles his connection way down.
I have literally tried EVERY publicly available firmware version and turned off anything that could adversely impact LAN speeds/QoS, etc. The ONLY thing that works is going back to 3.0.66 firmware before they included the Armor code or whatever code is negatively impacting throughput.
Nobody in the known universe wants to pay for a connection speed and have a router they purchased make it slow.
I believe you're trying to help Michael but the only real help would be Netgear fixing their firmware or giving us an alternate firmware without the Armor code that started throttling it. Whatever network inspection code they added between 1.0.3.66 and the next available firmware is what changed everything. They likely have changelogs/diff files internally that show the code that was added/changed and could likely fix this issue for all of us that doesn't turn our router into a paperweight.
This issue is affecting people with even 200mbit/300mbit connections. They're calling their ISPs support trying to figure out why they're not getting the speeds they pay for, etc.
This is something that should have been resolved when it was first reported back in 2019. If you do a Google search for 6700v3 LAN speeds you'll see there are loads of discussions about it.
Anyway, if someone does convince Netgear to fix it or find a solution that works, please let us know. Until then I guess I'm stuck at 1.0.366 or spending more money on something I could be using for another item I need to get a new router just for normal LAN wired speeds.
Dec 12, 2022Guru - Experienced User
Nobody has posted that brand and model# ISP modem/ONT they have connected with the R6700.
How are you speed testing? Wired or wireless?
What devices are you speed testing with?
Wired speeds should be to spec if after a factory reset and setup from scratch with out Access Controls, Armor, Circle, QoS or Traffic Meter being enabled I would expect. CAT6 LAN cable is recommended between the router and Modem or ONT. I presume this mode router has HW NAT or Cut-Thru acceleration support which is needed for higher speeds on the wire up to 1Gb.
Wireless speeds will never see anything near 900mpbs thru this router. Probably max out at around 300-400Mpbs on 5Ghz maybe depending on wireless device design and support.
I see v1.0.2.56 as a early version of FW. Wondering if this would change anything.
I've asked NG about if the beta that was mentioned could be posted or made available. No feedback yet.
