JRS_4's avatar
JRS_4
Netgear R6700v3 stop broadcasting 5Ghz SSID
The 5 Ghz SSID suddenly disappeared a couple of days ago.  Here is what I have done.
  1. Rebooted device
  2. Toggled the 5Ghz broadcast on and off in Advanced > Wireless Setup
  3. Tried different channels for the 5Ghz signal
  4. Updated the firmware - V1.04.120-10.0.91
  5. Factory Reset and re-configure router
  6. My devices do have 5G capability.
Unfortunately, it is no longer in warranty. Purchased it back in 08-2020.
Thank you for your assistance,
JRS_4
