woldy82
Aug 08, 2023Follower
Netgear R6700v3
I have Mediacom 1gig service will my router handle the speed? Is it a wifi 6 enabled with a firmware update which I did?
Aug 08, 2023Guru - Experienced User
You could see near 900Mpbs thru the router with a ethernet connected PC.
You not see anywhere near 900mpbs over with with this router.
This model router only supported WiFi 5 with in it hardware. Next generation wifi requires a hardware change. No FW can change that.
