woldy82
Aug 08, 2023Follower
Netgear R6700v3
I have Mediacom 1gig service will my router handle the speed? Is it a wifi 6 enabled with a firmware update which I did?
michaelkenward
Aug 12, 2023Guru - Experienced User
Should do. It offers 1000BASE-T on the WAN and LAN ports.
To see which sort of wifi your now ageing (2018) router supports, Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
As the title for this section says, WiFi 5.
Firmware will not update that.
But do you have Wifi 6 clients that can used it?
