aless
Aug 11, 2017Aspirant
Netgear R6800 VPN broadcast network
Hello, Is it possible to set up VPN servis to me same IP address as my home network (i.e 192.168.1.x), right now I get IP from different network (192.168.2.x)? I need this for broadcasting servi...
- Aug 15, 2017
I have never seen any directed broadcast forwarding options on consumer grade routers. It has long been a best practice for routers to drop directed broadcast due to concerns about DoS attacks.
TheEther
Aug 11, 2017Guru
It depends on the type of remote device. If it's iPhone, then it only supports TUN style OpenVPN, which uses a different subnet. You need a device that supports TAP style OpenVPN.
- alessAug 15, 2017AspirantThanks for the info. I use android (so TUN is my only option) - there is probably no broadcast forwarding options on my router to solve my issue?
- TheEtherAug 15, 2017Guru
