NGC2NGC
Mar 15, 2022Follower
Netgear R6850 dual band WiFi router, is https supported as login for admin
Is https supported as login for admin?
- Mar 15, 2022
You can try and see if its supported.
Being this model is a bit older, it may not.
Check for Web Page Management option under Advanced tab/Admin
Mar 15, 2022Guru - Experienced User
