MoarTelemetry66
Sep 21, 2022Initiate
Netgear R6850 forcing Netgear acct?
I have had a Netgear R6850 for a little over a year. During intial install I skipped using whatever 'app' it was the manual wanted me to install. Connected directly via lan, set my radio & wifi setti...
Sep 21, 2022Guru - Experienced User
I've been seeing the user name/password issue more.
I think the reason is netgear is requiring users to meet the minimum requirements on the password.
It might have updated at some point and yours didn't meet the requirements.
Did you change the password?
- FURRYe38Sep 21, 2022Guru - Experienced User
Ya I have noticed that 10 characters is minimum requirement know days. Upper case and a numerical character is needed as well.
