MoarTelemetry66
Sep 21, 2022Initiate
Netgear R6850 forcing Netgear acct?
I have had a Netgear R6850 for a little over a year. During intial install I skipped using whatever 'app' it was the manual wanted me to install. Connected directly via lan, set my radio & wifi setti...
michaelkenward
Sep 21, 2022Guru - Experienced User
MoarTelemetry66 wrote:
I notice now when trying to access the routers settings it asks me for my user/pass, then seems to want me to create a NETGEAR Account.
Access how?
The best way in us with the browser graphical user interface (GUI) and a wired connection.
You can then skip the steps where the router tries to be "helpful". These things are designed for novices who need hand holding. But you can usually kick the "wizard" into touch. Just look carefully at the screens you see.
MoarTelemetry66
I apologize-I should've been cleared. I connected directly to the router (WiFi) by using a browser and navigating to its IP address (10.0.01)
It does the usual-prompt for user/pass. Then it loads some SSO script, checks for an internet connection & asks for a netgear account. I can take screenshot if neccessary.
But in short no I'm using a browser. No..I haven't-the administrator password? It's not the default but it's very simple. I'll look into that-thanks.
That would still require some communication from my router to netgear tho.
