lancewo
Jul 16, 2023Guide
Netgear R6900 Readyshare link to Firestick
Hi Everyone, I'm setting my router R6900 as an Access Point Mode currently. My external drive is connected to the router via the USB port. I have no problem reading my external drive from my ASUS ...
- Jul 19, 2023
Michael,
I figured out the problem. I had to allow 'access' to the firestick first through the router setup. After that, I just use SMB to connect.
Thanks again for all your help.
michaelkenward
Jul 17, 2023Guru - Experienced User
lancewo wrote:
Is it possible for my firestick to play movies I saved on my external drive? I've been searching for 'readyshare' and 'firestick' but no luck.
If you are asking if you can plug the Firestick into the router, then answer is no. Readyshare is for storage and printers.
lancewo
Jul 17, 2023Guide
Hi Michael,
Not to plug the firestick to the router. My external drive would remain plugged into the router. However, I'm curious if my firestick could read this external drive?
I have an ipad that has no issue reading this external drive using SMB readyshare.
Thanks
