carp8000
Feb 03, 2019Follower
Netgear R7000 AC1900 with DD-WRT build 27261 not able to acces setting nor revert to Netgear
Back in 2015 it purchased above mentioned router. Did flash it with DD-RWT. For some years it has not been used.
Now it tried a 30/30/30 reset in order to factory reset the router and install ...
- Feb 03, 2019
In my dd-wrt experience you may need to use a serial connection to restore the Netgear firmware. This would require popping the router cover open.
Here is a writeup when using a MAC. Probably have two issues right off. Need of both a Ethernet dongle and a serial to USB cable.
michaelkenward
Feb 03, 2019Guru - Experienced User
carp8000 wrote:
Any suggestions to how to reinstall the netgear software? I´m using a mac-computer.
Talk to the people who create DD-WRT.
There aren't many people here who have deep knowledge of alternative firmware and Netgear certainly does not support it.
myersw
Feb 03, 2019Master
