mjparme
Feb 21, 2021Aspirant
Netgear R7000 admin web interface failed to start after updating to latest 1.9 firmware
I updated to the latest 1.9 firmware and when I did the admin web interface is no longer available. The wireless network itself came back up and can connect to the internet fine. I am up and running ...
mjparme
Feb 22, 2021Aspirant
michaelkenward wrote:I see no hint in your message that you have tried the factory reset.
I considered a factory reset but if the admin interface doesn't come back after a factory reset then I am stuck with a brick since I will not be able to get in and set everything up. At this point the router is working as far as being able to connect devices to it and get on the internet with it. I don't want to make my problem worse.
As far as power LED it is a solid white.
I have no other devices on my network that provide an admin interface on 192.168.1.1. I use a WISP so I don't have a cable modem. The device my antenna on my roof connects to doesn't offer a web interface as far as I know. It is just a PoE device that powers the antenna.
Based on the open ports on 192.168.1.1 it seems like it is probably the router. Port 53 (DNS) is definitely something I would expect to see open on a router. Port 631 (Internet Printing Protocol) seems like something this router would have as well. The other 4 ports are curious though.
>nmap -p- 192.168.1.1 Starting Nmap 7.91 ( https://nmap.org ) at 2021-02-22 08:49 CST Nmap scan report for 192.168.1.1 Host is up (0.0036s latency). Not shown: 65529 closed ports PORT STATE SERVICE 53/tcp open domain 631/tcp open ipp 1990/tcp open stun-p1 5000/tcp open upnp 7272/tcp open watchme-7272 20005/tcp open btx
I have actually had this router up on firmware 1.0.9 and 1.0.11 before. They were both so buggy I rolled back to 1.0.8. But I know there are security concerns with 1.0.8 so I decided to give 1.0.9 a go again. And now this. Every firmware past 1.0.8 for this router has been horribly buggy and I have actually ordered another non-netgear router because I am tired of the buggy firmware. I just have to nurse this one along for a week until it arrives.
michaelkenward
Feb 22, 2021Guru - Experienced User
To confirm that the router is on 192.168.1.1, because you have access to the wifi, you could track down the IP address of that. See if that lets you in.
I'm surprised you have had so much trouble with firmware on the R7000. It is one of Netgear's biggest sellers. Yes, people have issues with it, but not enough huge numbers to suggest it is terminally useless.
- mjparmeFeb 22, 2021Aspirant
michaelkenward wrote:I'm surprised you have had so much trouble with firmware on the R7000. It is one of Netgear's biggest sellers. Yes, people have issues with it, but not enough huge numbers to suggest it is terminally useless.
It has served me well for several years and was a solid router up to and including 1.0.8 of the firmware. Everything past 1.0.8 has basically made it unusable (or at least very annoying). The last time I was on 1.0.9 I got repeated router reboots (a few times per day). So I went to 1.0.11. That solved the constant reboot problem but 1.0.11 had a problem where it would just randomly drop the WAN connection for a few minutes then it would magically come back with no action needed. It would do this several times per day. Rolling back to 1.0.8 solved all my woes. Kicking myself for trying to go back to 1.0.9 last night, should have left well enough alone.
- michaelkenwardFeb 22, 2021Guru - Experienced User
I would suggest checking messages here for favoured versions, but your use of those numbers makes it hard to comment.
There are four 1.0.11.X versions, more than a dozen 1.0.9.X.
It has been several months since I was on a 1.0.11.x version so I can't remember the specific version. Likewise, it has been a few months since I was last on 1.0.9.x so I can't remember the specific version I last tried.
As far as the 1.0.9.x that was installed yesterday, that caused my admin interface to not be available, I can't tell you what version it installed since I can't access the admin interface. It was also downloaded by the router's update functionality so I didn't personally click on a download link so can't provide any link that was used.
- antinodeFeb 22, 2021Guru
> on 192.168.1.1. [...]If you want to be sure, then connect a computer, only, to the router.
You don't need an Internet connection to talk to your own router.
What's the computer's IP address? Presumably, "192.168.1.x"
(1 < x < 255)?> [...] I use a WISP so I don't have a cable modem. The device my
> antenna on my roof connects to [...]Not a very detailed description of that "device".
> [...] doesn't offer a web interface as far as I know. [...]
How far is that?
> [...] It is just a PoE device that powers the antenna.
I suspect that you're underestimating something. A simple "antenna"
does not have an Ethernet interface.
If your router were working properly, then you might look at, say:
ADVANCED > ADVANCED Home : Internet Port : Internet IP Address, to get
some idea of to what you're connecting it. (And where you might findsome other "web interface".)
> before. [...]Neither of those is _a_ firmware version. As I suggested,
V1.0.9.42_10.2.44 was found to be pretty satisfactory by many.> [...] They were both so buggy [...]
Not a useful description of anything.
> [...] I just have to nurse this one along [...]Doing nothing might be safer than doing something effective.
> to the wifi, you could track down the IP address of that. [...]
How, exactly, would that be more informative than the IP address of a
computer which is wire-connected to the R7000?> [...] people have issues with it, but not enough huge numbers to
> suggest it is terminally useless."huge numbers" of users don't have a dead management web server.
Obviously.
It is a white box about 2 1/2 x 1 x 1 inches. Has 2 ethernet ports and a plugin to provide it AC power. One ethernet port connects to the "Internet" port on the back of the router. The other ethernet port is connected by a very long Cat 6 cable to the antenna on my roof, this port is labeled "PoE". The only markings on it is "24V" (presumably it provides 24 volts to the antenna) and it has some stickers on it from my ISP with a support phone number.
> How far is that?
It sits on the WAN side of my router so it is part of the ISP's network not mine. So I have no access to any web interface it may have and it certainly doesn't get an IP from the router. So this device may have an admin interface but it certainly isn't available on my network.
The firmware download page shows downloads for 1.0.9.x and 1.0.11.x, I apologize for not remembering the exact x for versions I installed several months ago. Last night my router installed a 1.0.9_x_y_z. Again, I apologize for not memorizing the long string of digits.
I am not asking for help for those issues so no further description was necessary. It would have just confused things.
> Doing nothing might be safer than doing something effective.What kind of condenscending comment is this? Both my spouse and I are currently working from home and I can't be more aggresive with my troubleshooting because bricking my device is not an option. If I had a backup router I would obviously be much more willing to try various things and wouldn't worry about potentially bricking it. At this time all my devices can connect to the router and the router is providing me a route to the Internet. I simply don't have an admin interface which in the short term is fine, long-term I would like to have it back. Also, since I mentioned I use a WISP I am obviously rural so a store that sells routers is not just a quick trip around the corner. Making my problem worse by being aggresive with troubleshooting is not an option at this time.
