Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
Morganino
Jun 28, 2017Tutor
As suggested in above link, if you want to connect again to OpenVPN on R7000 you need to add:
tls-cipher "DEFAULT:@SECLEVEL=0"
in your OpenVPN for Android profile advanced configuration, but you're exposed to MD5 weakness vulnerability.
Hope Netgear will upgrade firmware asap.
Regards.
schumi2004
Jul 17, 2017Initiate
Adding that line to configuration makes it work again but at the end the current VPN implementation from Netgear is not safe and they should upgrade asap.
- GearNetRouterJul 18, 2017Virtuoso
Can Netgear get its s h i t together and fix the firmware? Why is NG not proactive enough to fix this in advance? WTF?
- karl11Nov 05, 2017Initiate
I'd like to use OpenVPN on my R6900 too, but MD5 keys are just reckless these days. Netgear needs to fix this.
