Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
ClarDold
Dec 20, 2017Apprentice
OpenVPN says MD5 will stop working in April 2018. See screenshot.
- 96708Dec 21, 2017Apprentice
Yup. I encourage you to file a BBB complaint. Need to throw the hammer down on NG or nothing gets down IMO.
- kuserDec 22, 2017Star
BBB complaint? Is that the way to go: https://www.bbb.org/consumer-complaints/file-a-complaint/get-started
Maybe we should all do that?
