Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
Diggie3
Dec 31, 2017Luminary
Also, if NG engineering is reading, I would say not only md5 signature but also size of the keys and DH param size are really not acceptable. Probably this has been optimized to minimize key generation time per unit, but I think this has to be improved.
juched
Dec 31, 2017Apprentice
Please do post steps. I played with ASUS Merlin Voetex for my R7000 and liked it a lot. Cpu usage very low and I can control the VPN certificate directly. Just wanted to use circle.
At this point I am planning to buy a real circle and get off the offical netgear firmware.
But, it would be good to know how to change it if I wanted to.
