Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
ClarDold
Jan 01, 2018Apprentice
I won't enjoy some pointers.
I don't need detailed steps. I might not want lots of hacking.
I have done things like mounting iso images for modification and such, using Linux tools.
If you message me directly, we could chat about how difficult it seems. I have done formal documentation.
If there's no update from Netgear, I might look to DD-WRT.
Diggie3
Jan 02, 2018Luminary
I have asked one of the moderators if it's okay to make a new post with steps, since I don't know if such things are allowed. I hope I get a thumbs up, since this will help people solve the problem themselves at least in the short term. When I hear back I'll follow up.
BTW, I did manage to get SHA256 certs working, and surviving reboot and firmware changes, so that's good news. Also, larger key sizes and DH params work too.
