Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
NG_Guru
Feb 25, 2018Star
I can confirm that step 1 can be avoided (R8500) by going to http://192.168.1.1/debug.htm and select "Enable Telnet "
Can anyone else confirm that telnet can be enabled this way ?
katsaw
Feb 26, 2018Guide
NG_Guruwrote:I can confirm that step 1 can be avoided (R8500) by going to http://192.168.1.1/debug.htm and select "Enable Telnet "
This also work for my R6220 router. Selecting "Enable Telnet" will enbale the linux telnet server inside the R6220.
