Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
Diggie3
Feb 26, 2018Luminary
That's interesting.
I'm not at home right now so I can't check my R7000 but one difference seems to be that on your device the OpenVPN configuration seems to be in /tmp/openvpn, whereas on my R7000 it's at a different location.
Can you please follow Step 4, then follow the part of Step 5 that tells you how to transfer the original keys from your router with tftp, but instead of sending originalkeys.zip send openss1.cnf. I would suspect looking at this file will tell us which files the router is really going to use. It might also be interesting to inspect "vars". Please check they have no confidential information before posting them, or send me links in a direct message.
It looks like some of those files are certificate signing requests that perhaps NG left on the device but I suspect don't actually need to be there (though you should leave them alone). ca.key probably is supposed to be on the key signing machine only so assuming your router is never signing new keys itself (afaik my R7000 doesn't) that probably isn't necessary either.
katsaw
Feb 26, 2018Guide
Diggie3wrote:
That's interesting.
Sure, I will try my best to get all the mentioned information. If possible, I will get all these files and attached.
It may need couples of days because I am not familiar with the operation of tftp files transfer.
Anyway, thank you very much for your attention.
- Diggie3Feb 26, 2018LuminaryNo problem. Following those guide steps should give you all you need to enter the tftp commands, but another way is to type,
cat openss1.cnf
cat vars
This will dump their contents into the console, so it's a bit messy but you could then copy/paste. - katsawFeb 27, 2018Guide
cat openss1.cnf
cat vars
This will dump their contents into the console, so it's a bit messy but you could then copy/paste.Sorry, I have made a mistake. The file name should be "openssl.cnf" instead of "openss1.cnf".
The text content of "openssl.cnf", "vars", "dh1024.pem" & "dh2048.pem" is attached in a single PDF file.
