Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
Boris1976
Mar 18, 2018Aspirant
Hi guys!
I've been using VPN service on my R7000 router for years without problems. On Windows computers it is still running. But I'm really angry while I can't make it run on my Android phone for several weeks. I have installed the newest updates on my Android phone and also on my router. I still get the massage "OpenVPN server certificate verification failed". How come such an elementary thing is not working well?! Will ever Netgear fix this?! Or is it somehow fixed? If not I will have to purchase some better product and never ever want to hear of Netgear...
Thanks in advance for answers. Have all a nice day!
