Morganino
Jun 26, 2017Tutor
Netgear R7000 and OpenVPN for Android App
Hi, since last OpenVPN for Android App update (v.0.6.73) downloadable at the following link: https://play.google.com/store/apps/details?id=de.blinkt.openvpn OpenSSL version was upgraded to 1.1 and...
- Feb 28, 2018
Thanks everyone for feedback so far. Attached is version 1.0.1. I fixed some typos, added a suggestion to clean up your tftp folder when you're done, and made a note about the OpenVPN version that's most compatible with the document.
Some users looking to work through this doc may find that they can avoid Step 1 by visiting this hidden page:
If the debug page loads and there is an "Enable Telnet" option then you got lucky. Note that either the debug page or the option to "Enable Telnet" may not exist on your device or firmware version. Remember to check that this option is disabled after you're finished because having telnet enabled is a security risk.
Diggie3
Mar 18, 2018Luminary
Hi pthorvald,
Indeed an update to OpenVPN has been released. I'll probably end up updating the doc to match it but haven't had time yet -- busy work schedule. I noticed that they say they patched the easy-rsa scripts, which is probably what led to you getting "dh2048.pem".
If anyone else is looking for the 2.4.4 installer to match the doc exactly in the meantime, the download is here:
http://build.openvpn.net/downloads/releases/openvpn-install-2.4.4-I601.exe
Glad you got your router patched up! :)
giantbike
Mar 24, 2018Aspirant
I have been lurking in this thread for the solutions from Netgear's firmware upgrade to solve the MD5 issue. After endless wait for their part and looking like there won't be such a postive outcome. So I took the action with the helpful tutorial from Diggie3 and finally sucessfully setup with the proper SHA256 signed certificates.
Here I would like to express my graditude to Diggie3 for setting up such a helpful and details tutorials, eventhough the procedure seems daunting, but with such details in explanations and the many helpful pictures attached. I was in no time come into any difficulty at all. Eventhough it took me quite few hours, and take breaks in between to digest the different stages of the operations :) At the end. it all come good with the new OPENVPN server function like before but with the new certificates.
Once again I like say as many thanks as i could to Diggie3 for your helps here. I advise those who still are sitting at the fence to wait for Netgear's team for the solution to give it a try.
- stereopticMar 30, 2018Tutor
Thanks Diggie3 for putting together that comprehensive manual! I haven't tried it yet, though. :( I have a back-up OpenVPN setup on a Raspberry pi if Netgear doesn't follow through by April 30. Not being critical, but just FYI I did notice on Page 15 that although I see a copy command on the screen grab of the screen, it is not listed in the list of commands in the text.
- Diggie3Mar 30, 2018Luminarystereoptic hey, you're right! I'll put it on the shortlist of things to fix! Appreciate the note!
